Web Analytics
Betti number
Betti numbers are important invariants in algebraic topology that describe the structure of a topological space by measuring the number of independent “holes” of different dimensions. The $n$-th Betti number, denoted $b_n$, is the rank of the $n$-th homology group $H_n(X)$. Informally, $b_0$ counts connected components, $b_1$ counts one-dimensional or circular holes, and $b_2$ counts two-dimensional cavities. For example, a torus has $b_0=1$, $b_1=2$, and $b_2=1$, corresponding to one connected component, two independent circular holes, and one enclosed cavity.
Formally, the Betti number is defined by $b_k(X)=\operatorname{rank} H_k(X)$, where $H_k(X)=\ker\delta_k/\operatorname{Im}\delta_{k+1}$ is the $k$-th homology group. Equivalently, it can be viewed as the dimension of $H_k(X;\mathbb{Q})$ as a vector space over the rational numbers. Importantly, Betti numbers measure the free part of homology and therefore do not detect finite torsion. For instance, the projective plane has $H_1\cong\mathbb{Z}_2$, so its first Betti number is $b_1=0$, even though its first homology group is nontrivial.
The Betti numbers can be collected into the Poincaré polynomial $P_X(x)=b_0+b_1x+b_2x^2+\cdots$, which provides a compact description of a space's topology. They are related to other fundamental invariants: for a finite CW complex, the Euler characteristic is $\chi(X)=\sum_i(-1)^i b_i$, while under suitable conditions on an $n$-dimensional manifold, Poincaré duality gives $b_k=b_{n-k}$. Betti numbers also appear in differential geometry through de Rham and Hodge theory, and they have applications beyond pure mathematics, including computer science, digital image analysis, and topological data analysis.
