Build Your Own Local AI Coding Agent
Build Your Own Local AI Coding Agent with Gemma 4 and OpenCode
Artificial intelligence is changing the way developers write software, and now it is possible to build your own local AI coding agent that runs directly on your computer. The combination of Google’s Gemma 4, Ollama, and OpenCode allows developers to create a powerful coding assistant without relying on expensive cloud APIs or sending private code to external servers.
The setup creates a personal AI programmer that can understand code, suggest improvements, debug problems, modify files, and help with development tasks directly from the terminal. Gemma 4 provides the language model, while OpenCode acts as the coding agent that connects the AI with your projects and tools.
One of the biggest advantages of this approach is privacy and control. Since everything runs locally, your source code stays on your machine, making this solution attractive for developers working on personal projects, sensitive applications, or teams that prefer not to use external AI services.
The process involves installing Ollama, downloading a suitable Gemma 4 model, configuring OpenCode, and connecting the two systems. After setup, users can interact with their projects through natural language, asking the AI to explain code, create functions, fix errors, or assist with programming workflows.
Although local AI coding agents may not yet match the accuracy of the largest cloud-based models for very complex software projects, they offer an impressive balance between cost, privacy, offline capability, and customization. For many developers, a free local AI assistant represents an important step toward more independent and accessible AI-powered programming.
