Kepler triangle
[Image: 960px-Kepler_triangle.svg.png]
Kepler triangle
The Kepler triangle is a remarkable right triangle that brings together two of mathematics’ most celebrated ideas: the Pythagorean theorem and the golden ratio. Its side lengths form a geometric progression with the proportions $(1 : \sqrt{\varphi} : \varphi)$, where $(\varphi)$ is the golden ratio, and the areas of the squares built on its sides follow a similar geometric progression.
Named after the astronomer and mathematician Johannes Kepler, who admired the deep relationship between geometry and the golden ratio, the triangle was actually known in earlier mathematical traditions, including works by medieval scholars. Although popular theories have linked the Kepler triangle to the design of the Great Pyramid of Giza, modern historical research finds little evidence that the ancient Egyptians intentionally used the golden ratio in its construction.
Beyond its elegant proportions, the Kepler triangle has several equivalent mathematical definitions that reveal its unique nature. It can be characterized through the three Pythagorean means—the harmonic, geometric, and arithmetic means—or by optimization problems involving the largest possible inradius of certain isosceles triangles.
 These alternative viewpoints highlight the triangle’s rich connections to geometry, number theory, and mathematical optimization, while its distinctive angles and proportions continue to inspire research and educational discussions. The Kepler triangle remains a beautiful example of how simple geometric relationships can uncover profound mathematical structure, making it an enduring symbol of the harmony between numbers, shapes, and the golden ratio.
