Probability underlies much of the modern world
Probability is presented as a mathematical framework for describing randomness and uncertainty, rather than a method for predicting every individual event. A key distinction is between an individual outcome and the long-run patterns that emerge from repeated experiments. For example, a fair coin has probability $P(H)=0.5$ of landing heads, but eight actual flips need not produce exactly four heads. The article emphasizes that probability depends on how we define the sample space, the events being studied, and the assumptions incorporated into our model.
The coin-flipping example illustrates an important principle of mathematical modeling: probability is not necessarily a perfect description of physical reality. Real coins are influenced by factors such as their initial orientation and the mechanics of the toss. Nevertheless, when a physical process is sufficiently sensitive to small variations, treating it probabilistically can provide a useful model. The article also distinguishes probability from frequency: a frequency is what has actually happened in a finite sequence, while probability describes the expected long-run behavior of a model.
The article then connects probability to modern technology. Artificial intelligence, particularly large language models, relies heavily on probabilities when predicting what token or word should come next. Cryptography also depends on randomness: secure passwords and cryptographic keys require outcomes that are difficult for an attacker to predict. In statistics and experimental science, randomization is equally important. Randomized controlled trials use random assignment to reduce systematic differences between treatment groups, helping researchers determine whether an observed effect can be attributed to the treatment rather than to other variables.
The broader message is that probability is best understood as a model for reasoning under uncertainty. It does not eliminate randomness or guarantee that an individual event will conform to the expected pattern. Instead, it allows us to quantify uncertainty and make meaningful statements about collections of events. This makes probability fundamental not only to mathematics and statistics but also to AI, cryptography, scientific experimentation, and many other aspects of modern life.
  • Probability models uncertainty: it assigns numerical values between $0$ and $1$ to possible events.
  • Probability ≠ frequency: frequency describes observed outcomes; probability describes the behavior expected from a model in the long run.
  • For a fair coin, $P(H)=P(T)=\frac{1}{2}$, but finite experiments can deviate substantially from $50$–$50$.
  • The Law of Large Numbers explains why empirical frequencies tend to approach theoretical probabilities as the number of trials increases:
    Xnn→pas n→∞.\frac{X_n}{n}\rightarrow p \quad \text{as } n\rightarrow\infty.
  • Probability depends on the model and its assumptions, including the choice of sample space.
  • Randomness can be useful rather than merely inconvenient: it is fundamental to cryptography and statistical experimentation.
  • Modern AI systems use probability to estimate likely next tokens:
    P(xt+1∣x1,x2,…,xt).P(x_{t+1}\mid x_1,x_2,\ldots,x_t).
  • Randomized controlled trials use random assignment to help separate causal effects from confounding factors.
  • A probability model does not necessarily describe every physical detail; its value lies in capturing the aspects of uncertainty that matter for the problem.
  • Probability is therefore a central mathematical language for reasoning about an uncertain modern world.
